Elbitrevnoc
Having just picked up a 2022 Hybrid Cayenne, I'm still getting my head around best ways to charge etc. For home charging (which is the only place I think charging will happen) I have the plug in, original Porsche kit. That includes a portable 7.2kW charger block, although my car car only has 3.6kW onboard charger. I've charged up the car overnight without any difficulty, using standard 3-pin socket connection and I'm not too worried about time to charge as I will always do so overnight. However, if anyone can help answer the bits I'm not sure I fully understand yet I'd be very grateful!
I appreciate that I'm asking a few questions here, but if any techhie gets a spare five minutes to answer them I'd be very grateful!
1. I presume the fact that I have a 7.2kW portable, plug-in charger doesn't speed things up if the onboard charger is only3.6kW - i.e., it's the car's onboard charger that dictates charge speed?
2. The charger gives me a 50% and 100% charge option and it seemed to me that 100% was quicker and caused me no issues. However, I'm not really sure exactly what is being changed by this function?
3. If I'm happy with overnight charging, there doesn't seem much point to me in installing a dedicated charge point at home. Most of these seem to be spec'd around a minimum of 7kW and I don't think that will help if my car is limited to 3.6kW charging anyway? There does seem to a limited number of 3.6kW chargers available, but I'm not sure I see the point if a standard 3-pin outdoor socket will do the job.
4. Having said point 3 above, am I even getting 3.6kW via the granny charger if a domestic plug only outputs a max of something like 2.3kW??
Thanks!
Thanks!
