i was reading that porsche are starting to get into 48v alternator systems so that turbo or superchargers can run using the hybrid system. I also read that they can give a boost in psi but really cant be the cheap ones. A proper compressor is required like Garrett. Anything else will not cut it.
anybody played about with this.
i looked into changing battery to 48v.
change alternator to support the charging of a 48v battery. Bosche are playing about with this.
i dont know how the wiring from the e-supercharger to accelerator works but installing it should be as per a normal supercharger mod. Connect from the induction cold air inlet.
