jwindwood
Guys
1985 square dash 944. One day last week, it wouldn't start-no fuel pump noise so I immediately suspected DME relay. Took it out, put in my (Untested) spare-still nothing.
Made up jumper wire, fuel pump ran fine, started normally. Resoldered both relays with no improvement. Bought a new relay (Genuine)-still no fuel pump.
Looked closer at the relay board with a view to wiring tests and realised that the earth terminal was missing from the relay holder (Terminal 86, IIRC). Took the fuse panel out and the connector had pushed through the back. Refitted it, fitted relay and the car started fine. Tested the other two relays and again, all started fine but now a new problem....
Car starts and idles fine, but as soon as I give it throttle it becomes lumpy and almost backfires. It is drivable, but not easily-coughing and spluttering at times.
Question-could this be caused by a poor earth to the DME relay? I noticed whilst I was refitting the connector that the wire has been cut and respliced poorly in the past and the terminals are looking past their best. I'm going to replace it anyway, but I'm interested to know if my car is displaying typical symptoms of this problem, or whether it's likely to be something else?
It seems a major coincidence that I have never had any running problems before this occurred.
Thanks for any advice!
