Early 944 DME relay location
The relays on a square dash 944 should be in the passenger footwell above the fuses if mine is anything to go by . I'm 300 miles from home just now so can't double check but think the dme relay is second in from the left on the top row .
OK, thanks for that. I've not fully checked the wiring out, but I think that the idiot who had it before me has butchered where the DME relay should be and replaced it with two standard relays instead, crappily fitted with choccy block and masking tape... amongst other bodgery on the alarm/immobiliser which is a right mess (but not the cause of the problem as it isolates the starter feed, all of which is OK).
