Hi All
I picked up a 986 Boxster 2.5 Tiptronic yesterday as car for my partner to enjoy a bit of roof down sun. Unfortunately on getting the car home, the roof has become stuck in the closed position (better than stuck open I guess!) and the roof warning light is lit on the dash. The roof worked earlier in the day so something has happened when I raised the roof on getting home. I suspect something has broken or bent in the mechanism as it sounds as though the roof motor is trying to drive on pressing the open button.
Does anybody know how I can release the mechanism with the roof closed so I can manually lower it and try to figure out what is wrong?
As it stands I can unlatch the roof and the side windows drop (so at least one of the latch microswitches is working), the handbrake light is on so the handbrake microswitch also works.
Pressing the open button results in a hum from behind (I assume this is the roof motor stalling as I also get a voltage drop and the dash lights dim). There is no movement in the clam or roof and pushing/pulling them by hand makes no difference.
After about 5 seconds the hum stops momentarily and then repeats. I get the same if I push the close button.
I can just about get to the clam linkage ball joints on the end of the ‘boomerang’ from inside the cabin. Should I force these off to release the clam so I can then just lift it up to access the space underneath?
Any suggestions appreciated!
