Is the Boxster S 986 ECU map really that far out as stock that up to a 19bhp / 31Nm of torque can be gained from a generic map swap? Is this at all realistic? Is this a true restriction of the engine by Porsche to hold back the 986? I guess not as the same power increase is listed for the 911's too. I was under the impression that Porsche used a decent adaptive ECU that would advance ignition very accurately using live feedback from the knock sensor. If this is the case, then surely there would be next to no gain from altering the ignition fields and I would guess Porsche to be running a fuel mixture on wide open throttle to take full advantage of the power available?
Does anyone have any experience of mapping a standard Boxster or 911? I am more curious than anything.
Gaz
Gaz
