944cabby
Chaps, on my martini 924 the previous owner had disconnected the connector on the electrc start valve (on the inlet manifold) and crudely attached two wires to it which go directly to the battery to start the engine up when the ignition is turned on.
It has also been converted from points to electronic ignition.
She starts and runs ok by this method but when started you have to pull the wires off the battery for it to tick over correctly.
If i try and start her by reconnecting the electric start valve it just turns over and won't fire up.
Can anyone give me any idea where the wiring from this electric start connector goes to (ignition barrel?Fuse box?) so that i can try and trace the fault.
Also did the early 924's have guide tubes for the oil dipstick?There doesn't appear to be one on mine.
Thanks in anticipation,
Ade.
Ade.
