Andy 944
Folks - I loath electrics, advice please
Square Dash 944 is I believe burning out window switches.
Had a fault last year, windows would fail, individualy, would go down but not go back up. I replaced faulty switch but it happened again.
I had all the block connectors replaced in the doors and 'A' pillar as they appeared corroded, again replaced switches.
Guess what happened last night, car is now parked in garage with drivers window down. Tried replacing with the other units in the car, now I have NO working windows AAAARGH [:'(] [
Now having slept on it-
1/ Should the windows work with ignition OFF? Mine does, is that a fault?
2/ If I leave the car for two weeks or more, the battery drains and I've not been able to locate the problem - is that linked to point 1.
3/ To avoid battery drain I plug in an optimate.
Anybody got spare 924/944 switches for sale?
Look forward to your replies
