Electric Window not working.
Andy B Aces High
Anyone help ?. My passenger door window has stopped working from both passenger and drivers door switches. Could it be a fuse or the motor ? Anyone removed door cards before and if so how do they come off ?
It's easy to remove the door cards. Just follow the instructions on the p-car web site:
http://p-car.com/diy/ard/
Check the fuses first. It would be frustrating to remove the door cards only to find a fuse was blown! The other thing to try is using the working window switch from the drivers window just to confirm you don't have two faulty switches. If neither of these is the problem, I would assume the motor has expired.
Thanks, will check for problems in the sequence you suggest. I need to remove the door cards anyway to replace the door handle rubbers.
