Electric window problems
- Thread starter zack
if not there is a shroud around the internal door handle this should pull off gently and this will reveal 1 screw then then further down the handle there is a plastic piece coiled around handle,this pulls off and reveals the other screw...
airbag sign on the door needs pulling off if it has one with a small flat bladed screwdriver and this will reveal a 4mm allen screw...
also if you lift the storage part if it has one and look in there their is a plastic screw in there..
hope this helps..
