Monkeythree
Trying to get my electric windows functioning properly but have run into a problem. With the car just sat there, ignition off, the relay is clicking away intermittently. It will give a burst of clicks for a second or two then go quiet for a bit, then a few more. The good thing is that having noticed this, I assume this is probably the cause of the battery drain that has caused me to leave the battery disconnected all the time.
So far I've tried disassembling and cleaning the contacts in all 3 switches and this morning I've tried a new relay. Still does it.
The windows work fine (or at least the passenger one does because I'm awaiting a new motor and regulator for the drivers side) but I can't live with a relay that drains the battery all the time.
I'm not great with electrics so this is puzzling me, especially that the relay is clicking with the ignition off. The windows don't operate with the ignition off but there must be power at the relay?
Any ideas chaps?
Any ideas chaps?
