Hello, Happy New Year to all. Looking for some advice?
The passenger side window has ceased working from both switches. The driver's side works OK.
If i understand correctly a single fuse (No.1 in luggage compartment) and a single relay (Relay no. 2) serves both windows? I see that this subject was raised in 2007 on this forum but thought other thoughts may have come to light since? Automotive electrics is not my best subject!
The passenger side window has always operated much slower than the driver's side so apart from a possible electrical fault something probably needs easing/lubricating.
On the assumption that i will be needing to remove the door panel to investigate - is this a straight forward task?
Any thoughts gratefully received.
Thank you
Tim
Thank you
Tim
