smallspeed
does anyone have a link to or a list of relays and fuses they can post for me? I have the manual that lists them, but its in french, and I spent most of my french lessons at school looking out of the window and dreaming about porsches [
Im looking for information on electric windows as the driver-side window in my car is in-operable; Im going to try and trouble shoot it while the weathers nice. I can't see anything in the list thats obviously related to windows, but Im guessing there will be a relay for each window, and one fuse for both (the passenger side window works fine from both switches so im assuming if this is the case the fuse for the windows is fine)
Im guessing there may also be a limit switch top and bottom on the mechanism somewhere to prevent the motor burning out at the top and bottom of the glass's stroke, and so if one of these switches is stuck closed this may also stop power getting to the motor. There doesnt appear to be a limit on the sunroof though, so I might be off track here..
My plan of attack is to swap switches, check fuses and relays, and check power to the motor.. if I dont find the culprit after that I will be back to pester further!..
if anyone has a list, or can just direct me to the right fuse/relay number Id be grateful...
thanks in advance
ben
thanks in advance
ben
