lesworth
Morning all.
I thought I'd take a look at the electric windows last night. Although the passenger window works fine with the switch on the passenger door, the passenger window switch on the drivers door does nothing (driver winodw works fine). The first thing I tries was to swap the two drivers door switches over. The same result so I guess that rules out a faulty switch. Does anyone have any suggestions as to what the problem could be?
I assume that all the contacts on the drivers door switches are OK as otherwise the circuit would not be completed? Or is it a bit more complicated than that?!
I just did a forum search and found a very useful wiring diagram which details the wire colours. One of the wires was definately blue so I suspect some work has been carried out in the past. Also the metal 'frame' that the switch clicks into are warped and corroded on both drivers door switches.
I'm slowly finding my way around my car, thanks to all your help!
