after 10 years of trouble free motoring something other than service items has gone wrong on the 993 - it s a weird electrical fault and I suspect an earthing problem but any suggestions gratefully received as I expect its trivially easy to fix if I can track it down and as the dealers 50 miles away its a lot of hassle to get the car over there if its something simple
it started with instrument lights going out when switching from side lights to main beam. Switch back to sidelights and they come back on. Further checking reveals off side rear side light also goes out when switchng to main beam and comes back when on side lights. all other side lights seem to be working OK. At one stage the instrument lights recovered and worked as normal but the tail light was still out when on main beam. Instrunment lightsthen went again when on main beam. I think the fog lights may also be affected but haven't had time to check through all possible combinations and work out what happens with them.
All ideas gratefully received - thanks
