Big Les
When flashing the headlamps whilst they are in the closed position, should the headlamps pop-up, flash and go back down again? Mine flash but the lights don't pop-up.
Clock light - I've replaced the bulb in my clock but it still doesn't work. Testing with a multimeter I get power into the clock to make the clock work but on the other two pins on the connector there is no power coming through to the bolb connctors when the light switch is turned on (the light in the cigarette lighter comes on OK). Is this likely to be a problem with the light switch? If so how easy is to remove the cover panel to get acces to the light switch?
Any assistance would be appreciated.
