Just got back from LeMans and expireneced a number of electrical failures over the course of being away (mechanically the car ran perfectly I'm glad to say other than bring slightly hairy on a very wet M20 on the way down)
* Firstly. The passenger electric window stopped working and I'm convinced its the relay. However, I can't find where the relay is, can anybody tell me where Porsche located it as it's not in the front boot compartment fuse box and doesn't appear to be in the engine bay one either. I can't find any details in Haynes as to where it may be located other than it does exist - its on their wiring diagram??
* No.2 - The cold air blower motor burnt itself out (and made a nasty smell in the process). Not yet looked at the manual for a difficulty rating on replacing one of these but wondered if any of you guys (or ladies) had changed one in the past and could give any good pointers. Warm air seems to be working fine so I guess the hot and cold systems have seperate motors??
No.3 - Noticed when the car's in reverse the reversing lights do a fairly good flashing disco impression. I guess this is a bad or faulty switch or connection at the gear box end but wondered if the switch was accesible without major dis-assembly work? Again, I've not yet checked the Haynes manual but I wasn't holding out much faith after its lack of descripitive assistance re electric windows.
Any asistance would be appreciated or, alternatively can anybody tell me if there's a better workshop manual around as the Haynes I've got leaves a lot to be desired compared to the Mkll Escort version they did......
Rgds
Antony
Rgds
Antony
