I've recently replaced the fuel tank in my 1976 Carrera 3.0, along with the sender unit, but not the pump. I've been tackling a number of other jobs as well, so it's been a while ( about 12 months)since the battery was connected and the engine last ran. Anyway, I put the battery back in place, but on connecting the earth terminal the fuel pump immediately started to run. The ignition wasn't switched on and I didn't check what else did or didn't work. I've tried a couple of times and as soon as i touch the negative terminal with the earth strap the pump starts running. Wondered if anyone had any ideas as to what I may have done to cause this, or what I can check to try to diagnose the problem.
Many thanks,
Richard
Many thanks,
Richard
