Electronic Boost Controllers
- Thread starter John Sims
AndrewS
Greddy Profec B-Spec 11 works well, is very discrete and has an overboost protect feature. It has switchable high and low boost, adjustable gain and you can choose to hold a firm figure to maximu RPM or have the boost taper off.
Graham Francis has one for sale. Personally I think they are excellent and do a good job. Worth 15-20 bhp if used correctly and the car is mapped to use the boost.
Regards,
Andrew
It is fitted in the glove compartment out of the way of (my) temptation.
I am still experimenting with it, seems a little complex in setting up so I am adjusting gradually, I get the impression an EBC can hold the pressure better and offer improved spike protetion of an MBC.
AndrewS
I can confirm that an EBC controls the boost better than a Manual Boost Regulator. The standard control mechanism deployed by Porsche is also a very good electronic boost control system. As this is integrated into the cars Motronic knock control system - it functions as an effective safety net too.
With an MBC (Manual Boost Controller or Regulator), you have no overboost protect. Most EBC units have a degree of overboost protect and you can tailor the speed at which boost builds and tails off.
The unit used in Jason's car was also used on the 402bhp car on Saturday. As you correctly point out - AFR needs to match the boost characteristics laid down by the controller, wastegate and turbo charger. As 1.2 bar is the realistic maximum that can be achieved on the 944 Turbo (unless making other modifications) - it makes sense to make the most of the available boost and an EBC helps achieve this.
Regards,
Andrew
It is programmable for two settings, Hi and LO, so you may decide to have a safe mode for everyday driving and a setting for track use. You can buy an addon which enables switching between the two to be done remotly, Knight Rider style.
Programming the Greddy involves setting a maximum boost pressure as a percentage 0% is stock and 100% is the wastegate limit.
You then have to set the GAIN, this is the consistancy, I think this is something to do with the sensitivity of the EBC control valve. (not sure) I know if I play with this the power delivery is very 'wibbly' or better described as 'flutters'
The next setting is to provide the maximum level of desire boost and enable an alarm to sound.
The final setting is to tell the EBC %age to decrease the boost pressure by when you get to the maximum. If you do get to the maximum and overboost, the origonal engine managment cuts power still.
When not in setup mode, the display shows boost, there is also a facility to store maximum boost reached too.
I guess the Greddy is very safe entry level model and gives a basic control of the wastegate.
Jason
eastendr
Switchable boost is a waste of time - god gave you a right foot to control the car [
If you were to use a switchable boost control, you would probably want to run slightly lower boost on the track where boost is sustained for much longer than in typical road driving where brief high boost may be more acceptable ( and indeed is part of the strategy of more enhanced engine management systems than found on the 944).
MBC's also vary a lot. Some give a very flat top, while others give a sloping boost curve - look at Simon Peckham's one for example
Rick.
Diver944
I plumbed in the Greddy and after a few hours of pushing the buttons (it is a pain to setup[
This is another instance where standalone shines. With mine you can select a different boost map for different gears, loads, rpms, coolant or oil temps etc. and the fuelling will be recalculated to suit the actual boost (and intake temps etc.) based on the parameters that were in use when it was mapped. You can also vary other parameters such as ignition with boost should you have a need to, and you can allow a short period of overboost to aid bursts of acceleration as Rick mentions above (plus anti-lag, traction control, launch control, full throttle upshifting, water injection, nitrous etc. etc.)
In some ways the 944 EMS was very advanced for its day, but it's a computer and it's day was when it was designed in the late 70's. Think how other computers have progressed since then. As I understand it it is crippled by the KLR being unable to pass boost data back to the DME to allow fuelling and ignition to be altered with boost, in other words aside from when knock is detected the DME is flying blind of boost pressure. Remember that Rck has also pointed out that the DME only measures temperature once (at startup) so it is also blind of intake temperature and only knows about abmient when the ignition was first turned on. Imagine how accurate that isn't. Now imagine how accurate that even more isn't if you start the car at 10am in your shaded garage on a spring morning after a frosty night and drive it for 3 hours straight in the sunshine so at 1pm it still thinks ambient is 7degrees when it's actually 17degrees.
I'm not saying the DME/KLR is bad, but it's not great. Look at Mark K's AFR plot if you don't believe me; 402bhp but a fuel plot like the Himalayas and relatively extremely poor torque. By comparison Rick's car has the same turbo and some other components but with a standard head and intake yet his still posted slightly higher peak power and much higher peak torque (like 10% higher) because it has an EMS that is capable of controlling the engine so much better. Mark's car must have a lot more to come when it's been mapped properly (and it can be better than it is now on the DME/KLR I imagine); a standalone properly set up would unleash a lot more from it.
Sorry that went a bit off from just EBCs; they are a good idea and much better than manual, but forget the Hi/Lo setting unless you have an EMS that can compensate the fuelling to match the boost.
I think there is room for improvement in my boost settings. Am I correct I can lean out up to around 12. (sorrt going off topic a little here)
(Plot courtesy of Rick)
From my boost chart you can see the PSI tails off to quite a low level, I think this is due to my safety net. If I can get this to flatten out would my torque improve?
AndrewS
The Motronic 3.1 DME actually supports 3 different Fuel and Ignition maps. These are selectable via the Region Coding and Impedence Adapter plugs. Hence, the Greddy Hi/Lo setting can select these maps as it has a switched output making this possible. This means (for example) you can select a 1.2 bar map via the Greddy and a 1.5 bar map just by switching from Lo to Hi on the Profec B Spec 11.
On the road, the AFR is much more level. Most of the plots from WRC do show the AFR going very rich as the boost builds. On the road, if you log the AFR to an LM1 - this is not the case (probably becuase of the effects of the intercooler with the considerable air coming over the car at speed). What's important with Mark's car is that the fuel matches the advance throught the RPM/load range. In this respect it is totally detonation free and safe (both on the dyno and the road).
As for standalone management. I agree - there are much more sophisticated systems around than the original Motronic 3.1 which is now over 20 years old. However, it's still a reasonable EMS and the engine still turns at the same speed and requires the same spark (although it is a little weak compared to direct coil ignition). We are currently looking at a new type of standalone which hopefully will be a little easier on the pocket than the Wolf 3D (an excellent system - but very expensive). Experience with the LS1 re-mapping has taught us a great deal about what can be achieved.
Regards,
Andrew
Diver944
ORIGINAL: ProMAX Motorsport
Excellent news
