i used my 2009 987.2 boxster on the 31st of December and all was fine. Used it again yesterday 3rd Jan and approx half a mile from home a message in white came up stating ‘Emergency Transmission Run’ I stopped the car without issue, ie the gears changed down as normal to 1st. I switched off the engine and restarted, no message so drove on for 15 miles or so and no message. Later I took the car out again, no message.
As I was worried I went out again this morning, ie from a cold start and the message came up again this time maybe a mile from home. Same procedure as yesterday, switched off and on again and drove on as normal.
The manual is of no use just says ’have fault remedied immediately ‘ if only I knew what the fault was.
had the car since October and driven, without issue, just under 2000 miles, now lost a little faith in reliability. Any help would be appreciated.
