Engine bay fuel lines
- Thread starter 422hp944
422hp944
blade7
Well-known member
ORIGINAL: 422hp944
Hi guys - Anyone know the part numbers of the rubber fuel lines that go to the fuel rail?? i.e...the main pressure fuel line, the low pressure return line and the small damper link line? I want to replace with original....cheers in advance
John Daly.
If your car has a 3 bar FPR you'll probably have to cut the fitting off the rubber fuel line and use a fuel hose clamp.
422hp944
ORIGINAL: Waylander
from that number looks like the change over was from 95ZKN101326 so that makes yours an earlier one
Feed line 951 356 919 03 £85.13 item 1A
return line 951 356 917 03 £126.80 item 4A
pet image 201-12
Thanks for that info. My friend has a 92 turbo cab with exactly the same fuel line configuration as mine?
422hp944
ORIGINAL: blade7
ORIGINAL: 422hp944
John Daly.
Yes....Its a 3 bar FPR thats on there. The main pressure feed line is standard though????
422hp944
ORIGINAL: Matey
I have a NOS fuel return hose for a M44.52 that came in a job lot of parts, no use to me.
Original part number 951 356 027 13 which I believe has been superseded to a new number, can take a photo if it's any help.
That would be great if you could?? Thanks.....
422hp944
ORIGINAL: Matey
I had 2 of them, the other I sold on ebay for £30 a year ago I never got around to listing the remaining one, if it's not the one John needs you can have 1st shout for it Frenchy.
Hi Matey....Yes...thats the same as my return line....I will send pm to arrange taking it off your hands!.....Cheers!
