pae
Hi all, I had the car in Parr the other day for an MOT and to replace the engine mounts and a gearbox mount and asked them to check out the cylinder compression and leakage in readiness for a Promax chip. I thought I had a strong engine (it should be if you see what someone paid Paragon to rebuild it 14,000 ago) and the results seem to confirm it.
Compression, 1 - 170psi, 2 - 175, 3 - 175, 4 - 180
leakage; 1 - 15, 2 - 10, 3 - 10, 4 - 10
Andrew Sweetenham tells me that's good stuff. [][]
Just need to save for the chip upgrade now as I spent a bit more than I intended to whilst it was at Parr []
cheers ........ Phil
