Engine cover bobbins
- Thread starter tref
Waylander
the top separates from the bottom which can be a real pain to remove from the cam cover, I just spot welded a nut to the plate, you can try tapping them round with a punch, but if you snap it off be careful you don't drill right through when you have to drill it out
if so try these,
they are exactly the same
https://www.avmountsonline.co.uk/bobbin-mounts/male-female-bobbin-mounts
just measure the threads and body size, the PET parts listing is wrong, there are only 2 mounts, if you fit 4 the cover hits the inside of the bonnet
so only two on the variocam badge, and just normal Stainless bolts and washers on the inlet manifold side,
I bought some for the cover, the fuel filter mount, the air box front stabiliser bar, about £14, that lot from Porsche is about £160
