Ian Bloxsom
Hi,
can anyone offer any advice? The spoiler has developed a mind of it's own. It rises whilst the car is in the garage, e.g. overnight. It then works normally when on the road.
However a further development is that I happened to be in the garage and heard a ticking sound coming from the spring loaded switch on the centre console. I turned the switch one way and the noise stopped, however in the other direction, as well as in the centre position the ticking noise continued.
The only answer was to pull the fuse, therefore the spoiler remains extended. Not a bad fault as it looks good. However it's only a matter of time before some Muppet leans on it.
The warning light on the instument panel still works and comes on when the car comes to rest at juctions etc.
Has anyone had any similar problems and if so is it a simple fix? Thanks.
