After 3 years of trouble free running on my 2000my c4, today on the way home from work the engine just cutout. No warning lights or anything just lost power and cut out. I tried to restart and the engine just cranked but would not fire. I thought I remembered that leaving the ignition on for 1 minute reset the dme so I tried this. After a minute or so the car started fine and I drove of again.
About a mile later the same thing happened again. I left it a couple of minutes, switched ignition on and off and then it started fine and then behaved for the next 18 miles home.
Strange, no engine light and the engine revs and performs fine. I have a obd2 reader for vag cars so I tried that, with no engine fault codes being logged. Messed around at home and can not get it to do it again.
Searched the forum and the only similar case I can find appears to be a crank sensor problem. Is there a way to check this with obd2 or multimeter?
Any other ideas what it could be?
I am tempted to just try changing the crank sensor but some better ideas and more focused troubleshooting help would be better than just randomly fitting new parts.
Any help appreciated
