Recently i was driving my 99 2.5 Boxster and hit about 5250rpm and lost power(but idled), pulled over and restarted ok. Shortly afer the Engine Check light Flashed for a few moments then stayed illuminated. At some point, next day, i disconnected the battery and reconnected shortly after. Engine Check light now out and she seems ok. This has happened before. Obviously something is not quite right. Thoughts please.
I've changed the plugs and coil packs, in last 4 months, k&n filter also installed. Cleaned the MAF. All at toughly the same time. Alternator also repaired recently.
