SambaMav
Well, just got my car back from Reading OPC for a minor service.............
First thoughts are they charged me £100 for oil, not sure when they started doing oil changes in a minor service and had I known I would have gone to Costco but that is a conversation for Monday but it appears that is not all I have to worry about :-(
1) The start motor turns over slowly, this could be the battery and as it is 10 years old not to surprising and as I use a trickle charger it could be hiding a problem with the battery. So new battery then, not a biggy.
2) I have misfires at low revs on bank 1 (all cylinders 1,2 and 3) which means it is lumpy at tick over, you know when stopped at traffic lights, etc and makes it tricky to crawl slowly when in a queue. Now this is more worrying especially as I changed the plugs and coil packs only last year.
3) I get a fault code meaning camshaft adjustment on bank 1.
4) Assuming they checked my coolant levels during the service, it is now below the Min level 30 miles later.
5) oh and a level 4 out of 5 RMS/IMS leak but I know about that and was waiting for the clutch to go before biting that bullet.
Now all together this seems to take me a dark place OR it could be 3 completely separate issues, of leaking coolant bottle, dodgy electrics to bank 1 and a corroded solenoid resulting in the lumpy idle. Am I clutching at straws ????
Anyone else had camshaft adjustment and what that could entail?
Just felt like sharing, probably off to GT1 as a first port of call.
Stu
