engine light
sniper
Hello,
The "engine check - drive to porsche centre" message has come on the onboard computer and the check engine light in the dash is permanently on.
Obviously going to take to get checked out/not drive in the mean time, but what could be wrong? Drives fine at moment.
Sniper
This happened to me a while back.
The 'fault' was diagnosed as a recorded misfire on one cylinder although I never noticed anything while driving, so that could be one explanation. My OPC just replaced the plug and coil for that cylinder and I've never seen the alarm since.
I had this light come on with a slight misfire over xxxMPH & it turned out to be a loose battery earth terminal.
Disconnected the battery for a period of time ( cant remember how long) re-connected it tightly, check light had gone out & car has run fine ever since.
Hope yours is as simple as that
Turns out the turbo had seized up - replaced under warranty - now 100 miles later engine light on again!
Guess there is some problem (eg fuelling) to the turbo - and this caused the failure.
Turning into a right saga - getting fed up!
Anyone else has similar problems?
Sniper
