DavidHolden
Hi,
Being a Cayman S owner, I recently convinced my father to buy a 2003 Boxster S, which seemed like a good motor for 8k. It seems in great condition but the engine management / emissions light came on whilst test driving it. The small independent dealer (who was very helpful) that we bought it from sent it to his local specialist who replaced at least 2 of the lambda sensors and tightened the exhaust bracket (I believe the OBD codes suggested these were the problem). This seemed to sort it for a while. After owning it for about a month and doing a couple of hundred miles or so the light has come back on again, which co-incidentally happened just after filling up with super unleaded. The tank was not especially empty before refilling.
The dealer has suggested he takes it to the indy he uses in Kibworth Harcourt, Leics and following a conversation with them I think they intend to change the remaining two Lamda sensors. My reading on the net seems to suggest that failures of multiple sensors is unlikely and that the OBD codes may be misleading in that there could be another cause (MAF etc etc).
Is this a common issue and any particular problems to look out for? The dealer thinks it should be ok to drive around 20 miles or so to have it looked at again.
Thanks for any advice
Steve
Steve
