I have a 996 3.6 and I have found that after the car has stood for a few weeks without being used it sometimes miss fires and runs very rough. It usually rectifies its self after driving for 15 to 20 minutes or after being left for a few hours. I thought initially it might be down to moisture getting onto the electrics, however it has now started doing this again after being in my garage. Has any of you had the same problem and what might be the cure.
engine missfire
- Thread starter searay19
Had a similar problem recently in my 993 rs, after long periods of garaged up i found starting up would take much longer than normal & engine misfire & generally running rough, put it down to condensation, I decided to replace the twin head distributor,
this cured the problem.
