George Elliott
I have had this question floating around for some time. I think I am broadly correct in the following background of the 944 and especially the 951.
A less sophisticated than today's, Porsche Cars intention was to develop the 944 and phase out the 911. (They gave a 924 the model designation Carrera GT and took it to Le-Mans successfully). (And fitted air injection to the 911SC[
When they were 80% down that route they bottled out, (I'm glad they did - they need the 911). But the 951 had been developed, and it was too good, - but it was too expensive to Can it. With a market for this spruced up 924 selling at £40k in the late 80's, it had to go to market.
To position it in the model Range where it would not show the 911 turbo or 928 up, the 951 had to be restricted, (un-like my old AP50 Suzuki[
] - 48mph, or 55 with a strong down-hill tail-wind[
] - I digress).
Hence, the 951 has loads of potential to make it the car it could have been.
I would, as I said value comments on how / what restrictive components to modify and replace. The cars had 220/250bhp as standard, and 0.9 bar? boost. The 2.5 four cylinder is bomb proof as we all know.
Recently I have noticed that a few cars have expired, which is sad/expensive, and I suppose I fear for my own.
I have a theory, "the engine is v.strong when new, no wear etc, but as it ages we mod them to produce more power, and because they are getting tired, (or we have a poorly engineered mod) - they pop.
My conclusion is that all the experience I see on here (and other 951 forums) should enable us to develop the car Porsche engineered, and its Marketing bods tried to bury.
I have a plan to build an engine,[>:] but wonder what is the "right spec". It is a daily driver not a drag racer, - Boost pressure must be strictly limited to 1.2Bar. Secondly, rpm is limited to 6800 as I figure the valve train and spark management becomes more difficult above this level. A vented head would eliminate the hot spot at the rear of the Cyl Head which seems to be where many gaskets fail, (mine incl[&:]). The car should be a true Porsche, - quick & reliable, and efficient - 25mpg at constant 56mph.. (Also capable of 12mpg on a hill-climb[
So, any comments for the 951-S2 engine spec, or perhaps 951 GT2[8D]. (every component, from the inlet snorkel to the exhaust tip)
I wanted to ask Fen, Sweettea and Indixx especially if that is acceptable, but of course I would appreciate any comments. - except "your mad", I know that.[8|]
George
George
