Engine Noise
- Thread starter reevers
adrian996
I would get to an independent as soon as you can before you start throwing your hard earnt money at any (currently, very desperate) OPC. IMHO they'll only find something else for you to worry about anyway. At the very least I would get a second opinion from an independent, in my experience they're just better at what they do than OPCs are - it's that simple.
All the best - let us know how you get on.
Adrian.
Thank you and your email made feel a bit more posative, yes my car has mobile 1 in it and maybe not the best oil for it. The same as you my car sits in the garage for somtimes a couple of weeks at a time and even if it is left for a day or two then the sound is there its not for a long time but longer than i would say it should be for this kind of car. I would be honnest i think this sound has been there since i have had the car almost 4 years, when they replaced the tappets last year i went in and they showed me a few of the warn ones, but if there was somthing deeper this would have been a good time for them to have found the problem (under warranty) If i dont get anywhere with them and Porsche i will take it to an independant, and am not going to pay for Porsche to take the engine out and then tell me i need a new one. I have used my OPC for over 3 years and they have been very good, i get a good deal (-25% of labour -10% Parts) as i am not near an independant the nearest over an hours drive i have found it easy to use the OPC. However i think this would be a good time to speak to someone else.
Look forward to hearing some more comments from the people that know these cars.
Phil
If you've had this noise for 4 years, surely it can't be too serious. I would second Adrian's suggestion of using a different oil. I used to get the occasional clatter on startup (bearing in mind I use it every day) but since changing to a 5W-40 oil it doesn't happen any more.
Where are you located? Maybe someone knows of a closer indy.
Diesel130
I'd agree with Richard, that if its always done it then don't worry, but changing the oil sounds like a easy step to try.
Any recomendations on a well respected Indy not a million miles from Cambridgeshire.
Thaks again Phil
