Engine Oil Level
- Thread starter Guest
The gauge did move when I topped it up but even when the oil level was back up towards the "full" mark it was still only showing as just over half on the gauge.
Not a problem in itself as long as you know what the relationship is between the reading on the gauge and the dipstick.
I need to drive mine all of the way to or from office (about 8 miles of no-chance-to-blast-it road) before it's ready for checking.
On my gauge: top of the red to top of the gauge seems to correspond to 1/4 to 3/4 of the dipstick range. ie the gauge is quite sensitive to the amount of oil.
This is the key. Refer to the gauge for an "˜on-going' reference to the oil level (means zilch when you're in motion) only when the oil's hot and you are stationary. This will give you a good indication, but there is no substitute for checking the dipstick level manually as you can actually see the level[
peterarcher
Peter
I drove my 993 back from Switzerland.
All the way over the Jura the roads were frozen and the oill guage barely moved.
Through France the oill guage struggled to get above the red so I was convinced that it must be low.
So around the Chapagne area I dipped into a service station, bought a couple of bottles and was impressed to discover that they also had Mobil 1.
So, all topped up -- with an extra 1/4 litre for the car, we set off to the Chunnel.
Massive traffic, big wait, oil level comes up and up --- to --- on the high side.
2000 miles later and I haven't seen it low !
QED --- dipstick rules, OK ?
Or if that's not possible go sit in a traffic jam for a hour, that sends the gauge up.
On the M1, perhaps?[
9k rpm, IMHO the full mark on the dipstick corresponds to halfway up the gauge ..
Cheers, Maurice.
It seems mine is normal after all and there is no cause for panic then!
Why do I get the impression that even if I was to hang onto the car for 10 years I'd still be learning stuff about it....?
