engine oil to use?
cococola
Just a quickie,5w 30 fully synthetic oil in my 2.5 lux with 113k on the clock...is this ok to use?
Alan
10w40 is slap bang in the middle of the range for oils recommended by Porsche
5w30 is also in th erange, but will be a bit thinner and and could lead to excess useage but it will be better for cold startups on a very cold winters day
Would recommend 10/40 or 15/50 semi synthetic as the fully synthetics were not around when they designed and tested your car
ORIGINAL: Gordon Attar
No need to avoid the synthetics, My car had c90,000 miles and mobil one when I bought it I have only used synthetic oil since (mostly mobil 1 motorsport and silkolene pro R) the haed came off at c180,000 miles the bores were still in excellent condition. That is after regularly hitting the rev limiter in the lower gears, putting out over 300BHP for most of the miles from 100k on and doing a few trackdays on slicks. I think it would have broken with lesser oil.
However on a 2.5 na with normal road use a quality semi synth will probably be fine.
Tony
