Engine Oil
I use Mobil 1 in my 1991 C2, is this a good recommendation, if so what grade should I use?
Mobil recommend their Motorsport oil for our ' older' cars with larger oilways -15-50, instead of 0-40.
Mel
Hi
FYI this oil is far too think for a 964 and its been discussed at great length here before , if you do a search you will find the threads .
Read this http://www.opieoils.co.uk/pdfs/tech-articles/10w-60-oil.pdf and speak to Tim at Opie he will explain all you need to know.
If you use it you could damage the engine , sap power and increase MPG .
I like you thought it sounded ideal but ooh no it's not !!!!!
I took it out ASAP aften a miles after I noticeed issues and looked into it further .
Hi Ian,
Thanks for the informed response. Apologies, I appreciate that oil has been done to death. Didn't come across this link on my search, much appreciated.
Thank's I will stay well clear in that case ;)
In case you need further assurance, Ian is spot on. I actually had that oil in mine for a few hundred miles. The car felt like it was bloated and lethargic. Never again!
Update,
Contacted Mobil (ExxonMobil) today. Spoke ironically to a German guy on technical. In a nut shell; I asked whether 'Mobil 1 10w-60 Extended Life' was suitable for our air cooled cars, they advised NOT! Its to thick an oil. while the cold start value 10W is ok, the upper value is far to thick for cars when running hot.
Although I have no written evidence from Mobil, this does however fully concur with the explanation given by Opie Oils, which Ian kindly provided the link to.
So, if the manufacture is advising against its use in our cars then enough said I would have thought!
