Engine Oil
- Thread starter Ian964
I have been advised to use 15w 40 semi synthetic,but all the sites (Shell,Mobile e.c.t) advise to use 5w 40 fully synthetic.
Local Porsche centre also advised 5w 40 Mobile 1
Now very confused about oil to use. [8|]
Thanks Chaps
964rsdatabase
Steve Brookes
Moderator
That's the opposite of what Unit 11 put in mine after the rebuild. They used 5W 40 for the run in period so that it had oil with a low 'cold' (5W) viscocity to protect it when starting from cold (when the most damage is done to the engine). Yesterday, when the run in period was completed, this was changed for 15W 50 mobil motorsport which has a higher 'hot' (50) viscocity to give it better protection at the higher engine temperatures experienced on track.ORIGINAL: m Thanks for your help chaps. Had 20w 50 mineral for run in my refurbished engine. Change oil to 5w 40 and seems to smoke on start up,so just looking to try something else to try and cure problem .I hope[&o]
Suits our engines with larger oilways....15W 50 mobil motorsport
