hi there i am wanting to give my boxster s a oil change and i am a little unsure which oil to use i know thay recommend the mobil 1 5w40 i have also been told a lot of people use the red line 5w40 oil wich is a very high performance oil as anyone used this oil in there boxster or should i just keep with the mobil 1 thanks byron
ENGINE OIL
- Thread starter byron
Just stick with the Mobil 1 More likely to be 0W40 however any of the grades in the handbook are fine
grahamwhite
take it to Kwik Fit, they will change your filter and replace your oil (with proper Mobil1) all for £39!!!
£45 to £50 - if you get it cheap []
Errr - Kwik-Fit?????
grahamwhite
Yes, Kwik fit! They are not all bad, if you speak to the mechanic ahead of the oil change and let him know what you expect then all should be well. As the £39 is cheap enough you could slip him a few quid cash to do an 'extra special job' to ensure proper service if you are worried. [link=http://www.porscheclubgbforum.com/tm.asp?m=597117&mpage=1&key=򑴞]http://www.porscheclubgbforum.com/tm.asp?m=597117&mpage=1&key=򑴞[/link]ORIGINAL: Mark Bennett Errr - Kwik-Fit?????
