Hi,
I was just flicking through the service history records of my car, and the below parts were used in an engine rebuild which was done at 60,000 miles, back in 1998.
What I would like to know is, whether this is a top end re-build or a total re-build?
Bottom end gasket set
Top end gasket set
Left + Right Tensioners set
Nuts and bolts
Con Rod
Big end set
Main bearing set
Intermediate bearings
Chain ramps
Con rod bolts
The car has now done 133,000 miles and runs perfectly.
What is the likely mileage before the next re-build?
Many thanks
Amo
Porsche 911 3.2
Top end gasket set
Nuts and bolts
Con Rod
Big end set
Main bearing set
Chain ramps
Con rod bolts
Many thanks
Amo
Porsche 911 3.2
