ORIGINAL: jerry911sc
Hi James
I've been going through this as well. The two options I got down to were
A) carbs and 6 throttle bodies which apparently will do the business with some tuning refinements - there were differing views on how much output would be added but mixed views on what it would do to driveability - I know of someone who bought a car with this conversion and hated it so much they sold the engine and replaced it with a 3.2 RS engine. JZ can do this mod, so can G Force and I'd be surprised if Jez Parsons couldn't do it the same or better.
B) Top end re-build. Capacity increase, new pistons, flowed head, new cams etc etc. Very good reports on driveability as well as output. ££ expensive. This is probably what I'll do eventually - after losing some weight (aircon for starters) and doing: wider wheels, tyres, new bilsteins, bigger torsion bars etc, strut brace, geometry and corner weighting, And then uprated brakes ..... to handle the extra power
Other options I looked at:
C) Supercharging - very mixed views. Autofarm can do it and would stand behind the work. But I have also been told that it will ruin the engine if not done right.
D) Turbo Pistons - have not got to the bottom of this one. It was a factory mod by request on run-out so I don't see why not but have been told A) it can be done and B) it can't be done Might depend on which SC engine.
Incidentally there was an SC with a 993 varioram engine and a 915 box at Brands doing the Speed Championship
Exhausts - see separate thread if you didn't already:
http://www.porscheclubgbforum.com/tm.asp?m=149732 anyway Pete covered this above.
