Engine removal
- Thread starter cbonetti
The gearbox/torque tube do not have to move, seperate at the torque tube/bellhousing interface, drop the crossmember, rear wishbone mounts, anti-roll bar, and the steering shaft has to be seperated from the rack to allow it to drop enough. The engine can then be lowered from its mounts, and with the radiator and a few other anciliaries out of the way, pulled straight forward, up, and away.
Hope this helps,
Regards,
Tref.
Undo both ends of steering column lower section, slide 1 back to allow other end to disconnect, undo tie rods and power steering pipes front wishbone bolts and then the 4 crossmember bolts.
Have you taken the rad out? I found it impossible with it still in, also dizzy and arm.
Good luck
Mike
What engine is going in? I put an 86 in my 83 944 and had to change the engine loom and most awkwardly the breather valve under the inlet manifold, also the fuel rail, various vacumn lines and breather pipes!
If you want to call me my no is in the sig below.
Mike
the engine is out of my 1980 ,924,it's going into my 1979 924 ,but the loom attached to the engine is a round plug on the 79,and the 80 plug is square,but i cant seem to find the temp wires on the loom i fitted and i dont have a spare connector block
Mike
924nutter
ORIGINAL: batavus
i didn't touch the gearbox,was no need to.
I was just enquiring as it looked like you were doing a major rebuild. Of course with the gearbox out the easiest thing to do is to undo to four bell housing bolts from the torque tube and draw that back rather than upset all your steering geometry, but as you haven't removed the gearbox the question is interesting but academic.
what a bitch of a job ,i hope i never have to take it out again,i can understand why a porsche mechanic would charge exhorbitant rates.they'd earn every penny.
will post some pics during the week.
now i have to work out where all the fuel pipes connect,to but trial & error is what it's all about.
mind you i can recall stripping a yamaha xj650 turbo years ago,wasn't that bad.
