Engine Running Badly (popping, etc)
- Thread starter DavidM777
I don't know if the ECU's of the 964 could learn, but I believe that on the later cars in a circumstance where the ECU has returned to it's default settings, the car should over a few gallons of fuel, re-learn the otimum settings.
In fact, I believe that some deliberately disconnect the battery to force a re-set which with high octane fuel, forces the ECU to re-learn the optimum settings for a higher power output ?
Hope you get sorted,
Cheers,
Kevin.
I went for the traditional approach - take the car out for a good old trashing! Then all seemed fine.
However, I then had a look under the lid and something was loose (joint between the big black pipe along the top of the engine between the air box and throtle body - ????) so I pushed it back together again and then took the car for another spin. All working well except will not idle now and just cuts out?
Any more ideas?
Ninemeister
In fact the last 964RS that had a 3rd party Motec conversion arrived with 275hp and left with 330hp.....
Ninemeister
The big jubilee clips did come loose and air was leaking in there. It was caused the a few bif back fires caused I think by the ignition systen getting damp after cleaing the car and then putting it in the garage before running it hot and then going off on holiday for a week.
I took it to Steve Bull in Devizes and he put it back together for me. All sorted now and running like a dream, but I do like the idea of 330bhp from ninemeister. I think a trip up country will be in order. I'll try to give you guys a call in the next few days.
Oldtimer - did Steve fix yours? He did mention a similar incident following a spin on Coombe.
Thanks everyone for all of your help.
David
Hello again, you may remember we met at the RS day at Oulton in March, you introduced me to Tony Taylor as I was looking for an RS and you felt I should be aware of going down the modified C2 route to gain something similar to the RS..
I have since bought a Ferrari Yellow RS from Tom Schmitz and am doing a day with Andy at North Weeald next week, do I need to be worried? My car is mint both cosmetically and mechanically and I dont want to goose it - should I hire the Elise instead?
THanks,
Kevin.
Now , there's nothing to worry about at the Andrew Walsh day , and you really do need to do it in the RS - its what it was made for . The RS provides a lot of driver feed back once you know how to feel it , especially if its LHD , and try to get as much seat time with AW next to you as you can. He's a quiet sort of bloke so you need to be proactive in asking questions etc , and do give him the opportunity to drive .
If you dont spin you are not being brave enough or you are too good and don't need the instruction ! You wont hit anything , but yes it does feel strange to barrel up to an imaginary corner that you know you have no chance of making [
There wont be much wear on tyres or brakes compared to say a trackday , and it wont matter if its wet or dry. If you have grippy tyres you will do the mini circuit a bit quicker but the main lessons are about understeer / oversteer/ transition between the two / weight transfer........with a bit of an intro to slip angles and threshold braking.
Do report back to this forum - the undisputed place to post which is why so many folk come hear to read stuff and marvel at Des's wisdom [
Thanks for the advice, I am really looking forward to it. I had an unscheduled trip into the infield at Combe the other week just after Folly and I am still not really sure what happened, hopefully the day will give me a good chance to get the car sideways under controlled conditions and learn how to (a) anticipate it, and (b) retrieve it!
Will post back as requested,
Cheers,
Kevin.
