Hi, I wonder if anyone else has encountered this problem and if so, how they cured it. It all started a few months ago, when starting the engine of my 2000 'S' (hot or cold), after one or two seconds I would hear a squeak. At first I was sure it was a belt slip problem, possibly caused by something (A/C compressor or alterator) cutting in and momentarily slipping. It wasn,t! Then I thought it was caused by a worn engine mount it wasn,t! I now think, as does my local mechanic, that it is caused by a leaking valve in the engine vacuum system. The sound has become worse and can be provoked easily by pulling away from rest without sufficient revs, or by pulling away from a corner in too high a gear. Has anyone encountered this? If so was it a valve? Which valve was it? Any help gratefully received!
Tony.
Tony.
