Just had the car serviced and some breather pipes replaced. The emissions were also reset as the car was running rich. However the engine now stalls when I remove the oil filler cap which didnt happen before.If you place your hand over the filler there is quite a lot of suction. Any ideas what could be causing this?
Engine stalls when removing oil filler cap
- Thread starter rayve
