Engine Stops when Checking Oil!
- Thread starter Graham-S
alex.powell
cheers
Alex
alex.powell
cheers
Alex
raypollock
alex.powell
Ok, that is easy, just take of the top hoes that goes in to the oil filler neck, one jubilee clip, and push the valve in the hose so the pointed parts faces you and then fit the hose. The restricor is facing you/filler neck, just enough to fit the hose again
Will be trying it tonight as the weather is good. It's a cheap part too. just under £9 with Vat after PCGB Discount.
Graham
