Engine Tin Ware
- Thread starter 993 C4
Your best place is OPC but your need to open the wallet as tin ware is not cheap or a few new tin bits do pop up on Ebay sometimes.
Yes there are a few pattern Tin parts around but having tried these they do not fit with the same quality and I reversed them out and went OPC and did the job probably.
You also might want to get the new ones painted as Porsche tin ware paint is like tissue paper and falls off as you look a it!!
So until someone make Stainless tin ware for a 964 we have to pay the going rate @ OPC for mild steel ;-)
gregmarshall
Steve Brookes
Moderator
ORIGINAL: 993 C4
Heck.......Does anyone supply after market alternatives ?
FVD do some of them but as Ian rightly says they're not as good as originals and not that much cheaper. If you buy originals get them powder coated to help extend their life a little.
FVD link
T911UK
ORIGINAL: bert gear
Dansk do some of the panels, good quality and cheaper you can see them on my website
Actually old chap, Dansk only do 2 tinware pieces for the 964, front left (which is cheaper from OPC) and the rear section which they have no stock of!
993 C4
I just need to clarify exactly what bits to replace !
Thanks again peeps.
Nick.
