Engine warm up, how long?
- Thread starter Madracer
Helen Goff
No.1 Poster
but, Porsches are great at feeding the driver information, so learn to read/interpret the feel & noise of your car.
Starting the engine
f Turn ignition key to ignition lock position 2.
f As soon as the engine starts, release the ignition key.
The first operation of the starter is ended automatically when the engine starts. If the engine does not start, subsequent starter operations will not be ended automatically. If the engine fails to start after 10 or 15 seconds of cranking:
f Wait about 10 seconds before engaging the starter again.
f When starting the engine, be ready to drive immediately. Drive vehicle at moderate speeds and avoid engine speeds above 4,200 rpm during the first 5 minutes.
f Do not let the engine idle to warm up.
I usually let the engine idle for 15-20 seconds where it changes from a faster to normal idle, then drive off keeping it below 4k revs until the coolant temp reaches 80, then wait another 5 minutes or so until the oil is up to temp (I don't have an oil temp guage) then hapilly give it the beans.
Circleace, Only driven it a couple of times but had a good blast round the Dordogne last week, fab roads and made the most of the Sport mode...Superb performance, handling and all rounf feel great factor.
Hope to get back to France next week for a few days, inbetween building garage in the UK for it.
In Germany, its actually illegal (probably in towns) to sit with your engine idling to let it warm up!ORIGINAL: snarf
Helen Goff
No.1 Poster
ORIGINAL: Madracer
OK thanks, start and drive it is......
enjoy. these cars are made to be DRIVEN[8D]
ORIGINAL: Rodney Naghar
Some of the manual's advice may be environment friendly based.
In addition to minimising fuel consumption it also has something to do with extending the life of the catalytic converter, I believe there was an article in PP a while back that covered this.
