I have a strange issue with my engine. Its a bit smoky..... mostly at high revs but also a bit on start up. Ive just changed the seals on the AOS and checked the breather. I even fitted another aos from a car that didn't smoke.
When the car was off the road getting its rebuild, I replaced the head gasket and re ground the valves. I also replaced the valve stem oil seals while I was there. I checked the bores at the time and there was no evidence of bore score.
The car used to give a wee puff at high revs before I put it off the road but not anywhere near what I get now. ( its not like James bond but you can see the puff in the mirror when your accelerating hard.
I've done a compression test and the results were good and consistent across the four cylinders.
Another piece of important information is that I inadvertently over filled it with oil by about a liter-ish. I then took it for a bast round the industrial estate where my garage was and got a huge cloud of white smoke.I instantly dipped the clutch and the car idled normally. I drove it back to the garage slowly ( only about half a mile ) and switched it off. I drained some of the oil after realizing what had happened. ( I said I needed to add oil and my mate did it with out telling me, I then added more without checking and over filled it. ) The car then wouldn't run until I changed the plugs. I think the oil killed them. Ever since then it has smoked a bit.I also put some Wynns lifter treatment in it as I had a noisy tappet ( now quietened down ). so i wonder if the thinning effect of the treatment could be making it worse or is there another reason. Could I have blown a seal some where? eg Valve stem oil seals. The car runs really well apart from this issue and to be honest its more annoying than serious but I would be grateful for a bit of advice before I pull the engine out and send it for a rebuild or stick another in.
Thoughts ?
I know some of you on here really know these engines well.
Thoughts ?
