erratic fuel gauge
pitzey
Just noticed today my fuel gauge is a bit erratic . It moves from half a tank to 3/4 of a tank .... really not sure what could be causing it .
Regards Paul .
Hi, I have had these issues. in my case I suspected the petrol tank sender unit, so I removed it and checked it out,as per Clarks Garage tutorial, it was OK. So next was an o/h of the connections at the back of the instrument panel, and then clean the " rugby balls " on the back of the printed circuit board.This procedure not only cured the intermittent readings of the fuel guage but steadied all the other instrument displays. Removal of the instrument panel is again covered by a Clarks Garage tutorial. I am trying to re find a tutorial on cleaning the circuit board connectors known as " rugby balls" because of their shape.
I had the same trouble with my temperature gauge. There were some blobs of solder on the back of the unit itself (i.e. when you take it off the instrument panel), but one had fallen off. Put some fresh solder on there and it's worked faultlessly ever since. See the pic on the 4th posting here : http://forums.tipec.net/viewtopic.php?f=25&t=20860
Cheers,
Bryan
