Hilux
I nearly sold it earlier this year but kept it as SWMBO made me build an extension.
Had the oil leaks looked at and its now fine, uses little and goes like stink. The more I drive it the better it gets.
Went to the R24 Holland WOTY and put 1100 miles on in a weekend, faultless miles that is. It even seemed to get faster and looser the more I drove it (and I drove it as it was meant to be driven I can tell you with a period at circa 150 mph on a german autobahn [
I am now a firm believer that they need to be driven regularly and quickly. So I fully intend to [8D][8D]
Decided this weekend to sort out the minor rust that is appearing on the lower f ront wing edges. Took out the wheel arch liners and found that the o/s wing is a new one so no issues as its just on the leading lower edge which has been sandblasted over the years. The original nearside has 1/2 inch of the lower ledge rotted back from the edge under the car but the under wing spoiler covers it up. Both wings are all `cu-rusted` and `waxoyled` so should last many more years.
I write to say I was amazed at how quickly I did it. Every single bolt (however rusty) came undone (even on the rusty lower wing ledge). The underseal and galvanising (and oil from the major sump leak) has meant that the car is solid underneath. I crawled around under it and you would not believe its 18 years old. Its not concours but its so well put together yet simple to take apart.
Bl**dy brilliant. I love it [
Upgrade itis is in the air this winter so I`ll be asking the experts many questions, watch this space.
ps: N/S rear damper (sachs) is leaking so I need to replace them. Any recommendations from you track day kings re adjustable ones?
