My 1990 964 c4 has an exhaust system (fitted when I bought the car) which does not have a threaded hole to attach the oxygen/lambda sensor to the exhaust system. The system apart from this looks standard with no bypass pipes.
Someone has therefore made up a connector that is just a wire from pin 1 to 2 effectively bypassing the oxygen sensor input to the engine management by making a permanent connection.
I discovered this as I was investigating poor fuel economy and the heavy smell of fuel that occurs at idle.
Is this a recognised modification or some sort of half arsed attempt at increasing power by so called 'tuning'?
I can't see how this would help anything other than forcing the car to run permanently rich.
Any help appreciated. (Or is this just the excuse I need to pay Haywood and Scott a visit?)
Chris
Chris
